Flooded Trunk
Old Feb 21, 2011 | 12:47 PM
ccsuhoops's Avatar
Default Flooded Trunk
92 900s
I have a wet trunk. Did the research, and understand (I hope) it to be the drain in the vent cover. So it was warm on Sunday (32 degrees) so I began tinkering. I was able to get the vent cover off easy enough, then removed the piece below the cover w/ the three plastic pieces pointing up. I noticed the clamp on the piece that I’ll assume is for the drain and then my questions began:
1. How do you clear this tube? I am having trouble accessing it as it is up and left. Can I pull on it?
2. How do you reattach this to the vent cover? I can hardly reach it from the outside. Inside?
3. Is there a trick to putting the whole piece back? I can’t get it to “pop” back in. Don’t want to force it on an old car.
Any help would be greatly appreciated!
Thanks
mglofgren
Apr 13, 2019 10:33 PM
saab93dad
Sep 12, 2014 11:03 PM
drhiii
May 22, 2012 09:08 PM
Saab Fahrer
Mar 12, 2009 04:53 PM
jeff1785
Dec 7, 2007 03:21 PM
