electrical problem with 1988 900 turbo
Old Apr 8, 2008 | 09:51 AM
Sambog's Avatar
Default electrical problem with 1988 900 turbo
i have a 1988 saab 900 turbo, i have the haynes manual for it too. my problem is that every once and a while my car will not start. it will just turn with the starter. i have checked to see that the spark plugs are sparking and they are. i then checked the fuel line and i found that no fuel was getting to the engine. i checked the fuel pump in the gas tank and it was not turning on. i took out all the dash board because the wiring scematic says that the relay for the fuel pump is there. i found on the right side of the cab under the dash board. i ran a line from the battery to the fuel pump line at the fuel pump and then used a multi meter at the relay to make sure it was the right one. the line to the pump and the line from the fuse and to the battery are all good. when i turn the key the relay does not click when it should. i am trying to trace the lines in the wiring schematic but i am having trouble finding where the brown-white line goes. i see that the violet line to the electronic unit for the fuel injection goes straight to the unit from the relay. in the car i am having trouble tracing that line back to the unit, even though it is just under the relay. can anyone help me with some ideas of why the relay would not be working? could it be that electronic controll unit for the fuel injection? or does the ignition switch seem more likely? if so can you help me trace the line from the relay to the switch? PLEASE HELP
also my gauage for the turbo is not working anymore and i dont hear it when i'm above 3000 rpm any more either. is there an easy way to fix that.
[/align]
Old Apr 29, 2008 | 01:03 PM
wrenching40plus's Avatar
Default RE: electrical problem with 1988 900 turbo
Do you hear the pump running when you wire it directly to the battery? Are you able to start the engine when you have the pump wired to the battery? Have you tested the relay... at least, can you hear it click when you energize the coil?
Old May 29, 2008 | 12:25 PM
Vultures Eye's Avatar
I'm not 100% sure where the Seats indicator relay/flasher unit is situated but it could be attached to the indicator switch as some cars are. The heater and light switches should light up,probably need some new dash bulbs. Hope this is of some help.
Old Nov 21, 2011 | 07:58 PM
lindasaab1988's Avatar
im having the same problem with my 1988 did you ever find out what it was?
mike8041
May 31, 2013 06:11 AM
MDineen
Sep 28, 2010 11:36 AM
