is it a wheel bearing ?
Old Aug 8, 2007 | 08:18 PM
rabbitsaab's Avatar
Default is it a wheel bearing ?
I just purchased a 97 aero, which tested how strong a telephone pole is down the passenger side . Car has a noise like drivers side bearing bad when loaded to the right . are front wheel bearings going bad common on 9000 aero ? also has a high pitched bussing noise ,like alarm going off which seems to come from right rear speaker, any help?
Old Aug 9, 2007 | 06:51 AM
Default RE: is it a wheel bearing ?
Can't hep with the speaker, but with the bearing: jack that corner up and try pulling on the wheel side to side. There should be o movement unless you pull strong enough to turn the steering. If there's any clicking when doing this it is the wheel bearing.
trex
Jan 22, 2014 11:12 AM
mikethebiker
Jun 9, 2013 09:29 PM
det293
Oct 18, 2012 05:46 AM
pmat
May 6, 2012 12:25 PM
Winged Sig
Dec 27, 2007 11:09 AM
