89 9000 no start after clutch
Old Dec 24, 2008 | 09:38 PM
DirtBagPhil's Avatar
Default 89 9000 no start after clutch
So heres the thing, I am a heavy equipment mechanic.......So I thought I could tackle this new clutch install no problem in my garage with no hoist............man was I in for a surprise.
So I pull the motor and trans, have the flywheel turned and install the new clutch put everthing back together...blah...blah......
Anyways I go to start the car and I have nothing, all the lights come on but no click.
I had to remove the battery tray and the remove the all the 12v leads on the juntion box, could I have wired that wrong?
After I had worked on the car for 2 days straight and It didnt start......well to be honest I just shut the hood an pushed it out side and havent touched it since.......so it could very well be a very simple problem...............now I think I have calmed down enough to try again...
Any Ideas??????
Thanks
Phil
Old Dec 29, 2008 | 10:41 AM
Default RE: 89 9000 no start after clutch
I'm not usre how the old 9000s have the wiring set up, but take a multimeter and check if there is power at the starter relay.
reidg
Dec 14, 2010 08:28 AM
fox
Jan 25, 2007 12:04 AM
