headlights always on
Old Dec 26, 2007 | 09:35 AM
nbsman's Avatar
Default headlights always on
When i turn the car up front and head ligts lid up ,**** that suppose to turn it off doesn't change aything ,i was thinking about auto mode ,but there's no such.
Old Dec 26, 2007 | 10:18 AM
Default RE: headlights always on
DRLs....you can disable them by pulling fuse 15 I believe...
Old Dec 26, 2007 | 11:01 AM
nbsman's Avatar
That's right i added the missing fuse yesterday and it was # 15,
but i'm still having problem with the horn
Old Dec 26, 2007 | 11:39 AM
nbsman's Avatar
just checked the horn fuse under the hood and it appears to be fine ,so in that case i suspect relay orwiring cutoff somewhere.Does anybody know how to check a relay?
Old Dec 26, 2007 | 01:29 PM
first off I'd check the horn itself. These things can go bad. Pull the grille off and you should be able to access the horn. Should be just a 12v wire and ground.
Old Dec 26, 2007 | 04:26 PM
nbsman's Avatar
just checked it visually looks ok all wires connected properly but i have to check the voltage and then i'll now where to look for the problem
Susanna Conway
Oct 23, 2016 03:46 PM
robinsonparker
May 4, 2015 06:47 AM
robinsonparker
Apr 16, 2015 05:12 AM
robinsonparker
Apr 2, 2015 07:11 AM
robinsonparker
Mar 2, 2015 06:34 AM
