NG 900 wont turn over
Old Jan 22, 2009 | 09:24 AM
thinkglad's Avatar
Default NG 900 wont turn over
What a great day....went to go finish a job and tried to start the SAAB........no luck, when the key is turnde to start I get no action from the starter, eventhough the security switchh on the fob has been pressed....another interesting thing I noted is that there is a fast clicking sound like a relay is cycling quickly from under the dash when the key is in the *on* position, at start the clicking stops....but thats it....Any suggestions ??[:@]
Old Jan 22, 2009 | 02:14 PM
Default RE: NG 900 wont turn over
Battery voltage is low...
Old Jan 22, 2009 | 03:05 PM
thinkglad's Avatar
Hmm...ok tried that, ( battery is only 1 month old ) however I put a 50 amp jump to it and have the same trouble.....I just remembered something, Monday I had the trunk open and locked the car with the fob....then closed the trunk and the alarm went off......does it need to be re-set ??
Old Jan 22, 2009 | 03:32 PM
If you hear clicking than it's not alarm related. It's possible that you have a bad ground or a bad starter too. The car wouldn't happen to be a manual transmission?
Old Jan 22, 2009 | 04:14 PM
thinkglad's Avatar
Yep, I had a service done and it turns out the negative cable was not connected tightly at the frame. Thanks for the direction.
Old Jan 22, 2009 | 06:24 PM
That would do it
SaabRocks
Jan 12, 2011 10:57 AM
presto123
Jul 30, 2010 12:23 AM
alexdrops
Mar 16, 2008 08:00 PM
cblack0127
Jul 6, 2006 02:36 AM
yammini
Dec 29, 2005 12:42 PM
