Warning chimes
Old Jul 20, 2007 | 01:38 PM
bravesfan362's Avatar
Default Warning chimes
Purchased my 2003 Saab 95 six months ago. All was well. Lately, when I turn off the ignition key, the warning chime sounds, the interior lights do not turn on and the key remote function is disabled. There is no message re. the key battery being low. I check to see that all controls that supposed to be "off" are.
Any ideas? Thank you.
Old Jul 20, 2007 | 05:22 PM
Default RE: Warning chimes
Check thae actual ignition cylinder. When you take the jey out it's supposed to "pop" up. If it doesn't it will cause the symptoms you're describing. It thinks the key is in the ignition and that's why it chimes and wouldn't lock with the remote.
Old Jul 22, 2007 | 12:10 PM
Thanks Roto:
Did exactly as you suggested and it worked. Spring must be worn, but with a little sidways pressure on the key when I turn it off all systems are go. Thanks again.
ohpoppy
Nov 19, 2016 02:30 PM
ThePoisonDonut
Sep 22, 2016 07:49 AM
the blaab
Apr 29, 2009 08:58 PM
the blaab
Apr 28, 2009 10:36 AM
Roto
Feb 24, 2008 12:39 PM
