Go Back   Saab Forums - Saab Enthusiast Forum > General Saab Forums > General Auto Related Help Area
Old 12-26-2007, 09:35 AM
Default headlights always on
When i turn the car up front and head ligts lid up ,**** that suppose to turn it off doesn't change aything ,i was thinking about auto mode ,but there's no such.
__________________
1999,9-3SE,4Dr,Manual.
Old 12-26-2007, 10:18 AM
Default RE: headlights always on
DRLs....you can disable them by pulling fuse 15 I believe...
__________________
1999 Saab 9-3 5-door Stg4
Philly Region SCCA
Old 12-26-2007, 11:01 AM
That's right i added the missing fuse yesterday and it was # 15,
but i'm still having problem with the horn
__________________
Old 12-26-2007, 11:39 AM
just checked the horn fuse under the hood and it appears to be fine ,so in that case i suspect relay orwiring cutoff somewhere.Does anybody know how to check a relay?
__________________
Old 12-26-2007, 01:29 PM
first off I'd check the horn itself. These things can go bad. Pull the grille off and you should be able to access the horn. Should be just a 12v wire and ground.
__________________
Philly Region SCCA
Old 12-26-2007, 04:26 PM
just checked it visually looks ok all wires connected properly but i have to check the voltage and then i'll now where to look for the problem
__________________
