posible fuel pump problem
Old Jun 23, 2008 | 09:47 AM
Gordo's Avatar
Default posible fuel pump problem
Can anyone help.
I am having problems with my old saab 900 (not turbo) not starting. It turns over but doesnt appear to be getting fuel. It will fail to start for a week or two then will start and run for another month before stopping again. Mr AA man said it was the fuel pump. Can anyone confirm if this is common and if this sounds like a fuel pump problem.
Cheers[/align]
Old Jun 23, 2008 | 03:55 PM
Default RE: posible fuel pump problem
did you try hitting the fuel tank from underneath? If it starts immediately after than it's the pump...
Old Aug 16, 2008 | 11:28 AM
llurkin's Avatar
You should also check the fuel line check valve.
Old Jan 4, 2009 | 09:10 AM
andrew65's Avatar
Fuel pump problem Hi.........m using opel corsa royale 1.6cc. Since yesterday the fuel[/b] from petrol pump[/b] is not intaking in engine.We also checked fuel[/b] pump[/b] relay and also all the fuses, but it is okay. Pls guide me on this......... [/align]
Old Jan 7, 2009 | 08:35 PM
boostpowered's Avatar
hey gordo i have a 89 9000 cd turbo and it did the same thing it turned out to be a small feeder pump attached to the housing for the larger pump that had went out and it was not letting gas through it i htought i had ran out of gas a few times and was left on the side of the road turned outi did have a quarter of a tank just wasnt enough to reach the main pump
i ended up dropping my tank and getting a racing fuel cell and an msd pump havent had a problem since
klwiley07
Jan 31, 2011 02:46 PM
BadBetty666
Sep 26, 2010 04:31 AM
LEOCANCIO
1974-1994 900
Aug 7, 2008 06:33 AM
mullinator
Aug 4, 2006 09:15 PM
OSCARMONCADA
Nov 14, 2005 09:08 PM
