BOV
Old Nov 22, 2006 | 01:44 PM
Saab011188's Avatar
Default BOV
im trying to figure out a way to install a blow off vale on my 2001 93
Old Dec 5, 2006 | 08:58 PM
triblk6spd's Avatar
Default RE: BOV
me too. just got the car today.
Old Dec 6, 2006 | 04:26 PM
Patrick's Avatar
Default RE: BOV
so the system has no BOV? does it have metal piping between the intercooler and the throttle body? if not, thats the first step.
Old Feb 20, 2007 | 10:33 PM
Default RE: BOV
On a turbo9-3 you can only have a BOV if you have a T5(T stands for trionic)car(red DI cassette from the factory anda MAPsensor). If you have a T7 car (black DI cassette from the factory and a MAF sensor) you can only get an upgraded DV (Diverter valve) and can not vent to the atmosphere. On a T% car you would just disconnect the hose from the DV going back into the intake, plug the hole in the airbox and replace the DB with a BOV. T7 cars can not have that.
Old Mar 4, 2007 | 08:59 PM
turboAERO's Avatar
Default RE: BOV
on a 2001 9-3 it will put the car in limp mode, like stated by roto if you put on the bov to a t7. I also have a 2001 9-3 and learned on my own expierence about this, the only thing you would notice first is the check engine light will come on but the car will run normal in good temp. but when its colder out or really hot the car will idle bad and possible through it into the limp mode and that really sucks...so the best things you can do for sound from under the hood is an open cone filter system, you can buy the forge or other brands bpv (but really is a lot of money and not neccassary until you are really starting to get power out of your car) and also take the heat/sound insulation off from the hood....good luck
Old Mar 9, 2007 | 06:39 PM
Default RE: BOV
I just ordered a Forge BOV myself:-D Gotta love having T5
Old Mar 9, 2007 | 09:00 PM
arckeymolarkey's Avatar
Default RE: BOV
What about a 2003 9-3?
Old Mar 9, 2007 | 09:10 PM
Default RE: BOV
No go there. Sorry, the best you can do is a DV
Old Mar 10, 2007 | 12:00 AM
Default RE: BOV
Can I get a performance DV to give the WOOOSH and not throw a code? what can i do?
Old Mar 10, 2007 | 12:28 AM
Default RE: BOV
The whoosh sound is from the valve dumping to the atmosphere. No, you can't have the sound on a T7 car unless it's coming from your intake and than it's not really that noticable.
