Key not accepted
Old Dec 24, 2010 | 12:23 PM
utc18's Avatar
Default Key not accepted
2004 SAAB 9-3 Linear
I was doing work to the car. I had it on jackstands for 3 days and the battery was removed (car was lockeD).
I basically changed the inner and outer tie rod anyway thats not the problem.
I then placed the battery back and alarm sounded. I clicked the unlock button and it stopped and unlocked the door.
Now I go in the car it wont turn the key nothing displayed.
I go back out and remove the battery terminals and reput them. I get back in the car and it says "key not accepted".
I tried doing the following as I read in the forums.
I put the key fob in the ignition and click the unlock button 4-5 times nothing happens. I cant turn it off the unlock position.
I get out of the car and try it and nothing happens.
I tried pressing any button on the remote and the only one that does anything is the panic button. But when it beeps and alarm goes off because I clicked the panic button I can press any other button on the remote and it will stop.
One thing I noticed.
The steering wheel is not locked and i cant turn the remote in the ignition at all.
Someone help!.
I took the battery for testing and they said its fine.
I tried putting the key in ignition and pressing the unlock 5 times. nothing happens.
Old Jan 1, 2012 | 05:07 PM
Jibbin19's Avatar
So I was in pretty much the same boat for the past five days but when I saw your post...I decided to try what I could before replying...and some how I got the key to turn and my car started.
Heres what I did...and I dont know which part worked or if I just got lucky.
I disconnected my negative terminal...and checked all my fuses. I had to pull all the ones on my driver side to see them...and number 11 had a 15 amp instead of a 10...so i switched it.
after i checked all the fuses...I pumped my brake 5-6 times...because I heard that does something good to the computer.
I reconected the negative terminal. Got in closed the door and put the key in. I tried to turn it...it didnt work.
I turned the steering wheel back and forth...I pressed the lock, and unlock, panic buttons separatly on the key while in the igniton...didnt work...
Then heres the part that I think did it...I grabbed the shifter...which is currently in park and put presure down and forward on it to get the kinda click you would get from a torqe wrench. Then I tried the key (can remeber if I jiggled it a little or if it turned right away.) and the car turned on.
Lol, so try it out. Let me know if it works and I hope my car works tomorrow for work
troop2kewl
10
Jun 6, 2023 04:53 PM
slane
Aug 19, 2012 07:28 AM
scotety
Jul 12, 2011 08:49 AM
saheed
Jun 29, 2011 07:16 AM
nethereal
Jun 27, 2011 04:02 PM
