Xenon Headlight Q
Old Jan 24, 2008 | 10:39 PM
saabthusiast's Avatar
Default Xenon Headlight Q
Hello all. I Have a q bout my 2003 9-3. The SID reports a low beam malfunction. I thought it was the bulb except I noticed as the car is started, the headlight comes on for a split second then shuts off. Is this a ballast problem? I thought since it turns on for a split second that it probabaly was not the bulb (Damn things are $200). Any help would be appreciated and if anyone else has experienced the same problem, what costs are we looking at? Thank you all in advance!
Old Jan 25, 2008 | 07:53 AM
Default RE: Xenon Headlight Q
are the HIDs stock or are they an aftermarket addition?
Old Jan 25, 2008 | 06:46 PM
They Are the stock.
Old Jan 25, 2008 | 07:17 PM
Sounds like ballast...I was toying with HIDs today and had that same problem with a set of stock infinity HIDs....swapped balasts and it worked...what happens when you actually turn on the headlights? DOes one side come on?
Old Jan 28, 2008 | 11:18 PM
Yes one side does and the other does not. Have checked the fuses. How long do the HID's last anyway? This is the first time i have had them. Thanks for the reply btw Roto! I figured it might have been the ballast. BTW is it a dealer only part?
Old Jan 29, 2008 | 06:31 AM
well....it's not a dealer part only, but I would get one from the dealer...but that is coming from a person who never dealt with saab HIDs...I'm surethey use something common in other cars, I just never seen what exactly...I know that OEMHID systems easily last 7 years without replacement...
Old Jan 31, 2008 | 10:51 PM
So here is another Question. Now the other HID is turning purple instead of the bright blue. What does this mean? Is this light going out or does it relate to a drop in voltage somehow and the full potential of the bulb is not being utilized? Thank god for tax returns. Not the way I wanted to spend them though.
Old Feb 19, 2008 | 10:52 PM
So after all that, I found out it was both bulbs. Expensive!
Susanna Conway
Oct 23, 2016 03:46 PM
biker50610
Jul 29, 2016 06:59 PM
rupenzelleo
Jan 2, 2015 08:26 AM
JeffR
Aug 17, 2011 03:12 PM
Onassis91
Jul 20, 2009 01:14 PM
