Whistling Turbo?
Old Mar 4, 2008 | 09:37 PM
staffmonkey's Avatar
Default Whistling Turbo?
I was on my way to pick up my son the other day and heard a clear whistle coming from the engine. When I let off the gas, (the engine was still cold) it stopped and didn't come back. I haven't heard it since.
Here's my question: I know that a whistling turbo is a sign of failure, but can an "intermittent" whistle be a sign of something besides failure? If not, any guesses on how long I have until the turbo fails?
Thanks.
Old Mar 5, 2008 | 07:51 AM
Default RE: Whistling Turbo?
Well whistling doesn't necessarily mean that it's about to blow. I had a 9-3 with a constant whistle from the turbo and as far as I know it still runs 20K miles later. If at some point you have the downpipe off for some reason - check for shaft play, if there's shaft play you can rebuild the turbo...either do it yourself or you can send it off to someone. It's not really difficult to do.
Old Mar 7, 2008 | 09:19 PM
Thanks, Roto. I'm not sure why I'd ever happen to have the downpipe off, but if I do, I'll check for it. Can I assume that I'll know "shaft play" when I see it, or is there a spec that can be measured with a Mark I Eyeball?
Old Mar 8, 2008 | 10:15 AM
if you can wiggle the shaft than you've got shaft play...
Old Mar 16, 2008 | 07:43 PM
alexdrops's Avatar
The turbo in my 06 9-3 makes a a similar noise; the cars has close to 26k and runs great. I dont think theres a problem with the turbo. I kinda like the noise it makes hehe
Old Mar 19, 2008 | 11:40 PM
popcorn's Avatar
ORIGINAL: alexdrops
Same.
My 99' 9-3 has a similar "whistle". It's more of a suction sound to me.. Thinking of mounting a BOV to better accentuate it.
Old Mar 20, 2008 | 12:40 AM
a sucktion noise is the bypass valve operating...also normal
Old Mar 20, 2008 | 11:09 AM
alexdrops's Avatar
Oh yeah...suction noise and the whisteling noise; both i can hear on my 9-3. Cant wait until it gets warmer so i can drive with my windows open and listen to those awesome noises even louder, especially after ill install an air intake
merickrc
May 8, 2012 05:25 PM
argoolsbee
Jan 21, 2011 08:59 PM
presto123
Jul 30, 2010 12:23 AM
ibgummy
Apr 19, 2010 07:42 PM
Terry
Jul 17, 2006 11:08 PM
