I Need More Boost !!!!!
Old Jul 3, 2007 | 09:17 PM
Krsmed's Avatar
Default I Need More Boost !!!!!
I have a 200493 and I am very excited about the turbo. It is 99% of the reason I got the car. I have installed a very handsome B&B Cold Air Intake and besides just getting a great sound it has also enabled my Turbo to spool up much faster. I want to increase my Boost PSI. What can I do to make this happen? I was looking at BOV and doing my research and I have to be honest that I am not sure how to mover forward.
Thank in advance.
Old Jul 3, 2007 | 11:32 PM
Default RE: I Need More Boost !!!!!
I don't believe that you can use a BOV on your car since I think it has a MAF sensor...next thing to look into is a larger downpipe and exhaust, that will decrease spool-up time too.
Old Jul 4, 2007 | 03:56 PM
Krsmed's Avatar
What is a down pipe? Also, what exhaust is recommended? I would not know where to begin to look as I am not an expert on exhaust. If the BOV will not work then what could I install to increase boost PSI? My car has a Mass Air Sensor and I think that is diffrent from a MAF. The short of it is I am looking for more HP and I do not want to play with the cars engine too much. Increased boost PSI would satisfy my needs. If it is 15PSI stock I would like to get it to 20PSI. Something must be limiting the turbo's PSI potential.
Thanks
Old Jul 4, 2007 | 05:19 PM
mass airsensor is a MAF. A BOV wouldn't have increased boost. All it would do is give you the soundeffectsCheck your private messages.
Old Sep 27, 2007 | 09:42 AM
hawaiisaab93's Avatar
the BOV will work...i have a 03 93 and i had a BOV professionally installed and I havnt had a problem with it yet...no "limp mode" and no "check engine" light and my accel. is the same as it was...
Old Mar 20, 2021 | 07:20 PM
AkersTM's Avatar
im definitely interested in what you may have recommended
SlickSAAB
Apr 4, 2012 03:14 PM
Saab011188
Oct 11, 2009 04:46 PM
900SE
9
Dec 2, 2008 11:23 AM
Caption
Nov 13, 2008 09:24 AM
9000Aeroguy1
Jul 25, 2006 05:30 AM
