90,000 mile service
Old Mar 23, 2009 | 12:15 PM
wiscodread's Avatar
Default 90,000 mile service
Hi guys, I'm new to this forum, so just like to introduce myself. Hi. anyway, recently bought '02 9-3 turbo and would like to do the 90k service on it (at lest as much as I can without taking it in) and I'm wondering what any of you, who take meticulous care of your saabs do, including upgrades on fluids, spark plug wires etc. thanks in advance
Old Mar 23, 2009 | 01:55 PM
boostpowered's Avatar
replace oil with synthetic,replace oil filter
spark plugs and wires
air filter
check all fuel line and connections for damage and leaking or dry rotting replace if needed
fuel filter
charcoal canister
check crankcase ventilation system(check connection of hoses,inspect check valve)
o2 sensor
check belts
cooling system flush or just drain and refill
check connection on radiator hoses
replace themostat
replace battery if the stamp on current one is not to date
check headlights,taillights,turnsignals,horn,defrost,ele ctric mirrors,door locks,windows,etc
replace transmission fluid,filter
check suspension
check rod ends for play
check tire tread
power steering fluid top off if needed
check brake pads
top off brake fluid if needed
replace cabin filter
lubricate hinges and latches
matt224
Jul 4, 2013 12:29 AM
joseywales11
Apr 27, 2011 05:16 PM
cherokee1122
Aug 30, 2010 09:58 AM
roverguy
Apr 26, 2007 09:06 AM
Bathory
Jul 31, 2006 06:36 PM
