Electrical system
Old Sep 29, 2005 | 09:28 AM
CTGolfer's Avatar
Default Electrical system
I have a 2001 95 wagon SE... every time I turn off my high beams I get the chimes that says "front head light failure." But when I check the lights they're fine. I have also gone thru 6 bulbs in the last 18 months, both front and back. Any thoughts to solving this issue?
Thanks for all replies,
J.
Old Oct 3, 2005 | 09:31 PM
Patrick's Avatar
Default RE: Electrical system
it sounds almost like you have too high of power being sent to the lights...have you checked with dealership to see if this may be a common issue?
Old Oct 31, 2005 | 09:04 AM
CTGolfer's Avatar
They're the ones who installed the bulbs.
Old Nov 1, 2005 | 04:06 PM
Patrick's Avatar
then take it back and complain.. if they give you a hard time, ask for a corporate number.
Old Dec 24, 2005 | 05:32 PM
flugie's Avatar
we have a 95 95 se sedan and it has a problem w/taill light bulbs-brake light failure warning comes on.it consistantly blows a bulb every other week or less. any ideas?local shop has not been able to figure out problem w/out spending alot of my money to find it.thanks for any help you may have!!
Old Mar 25, 2007 | 01:54 AM
stevers's Avatar
Don't touch your bulbs. The oil from your fingers is what is blowing out your bulbs prematurely use rubber gloves or very thin cotton ones. This will greatly prolong the life of the bulb...Trust me been there many times with my 9-5
Good luck.
rupenzelleo
Jan 2, 2015 08:26 AM
slane
Aug 19, 2012 07:28 AM
gmwarranty
Feb 26, 2011 06:21 PM
Trpsicor
Sep 26, 2010 02:00 PM
