Saab Forums - Photo Galleries - Create an Account
Go Back   Saab Forums - Saab Enthusiast Forum > Saab Model Line Up > Saab 9-5
Old 10-31-2007, 12:31 AM
Default 1999 9-5 Turbo
Does anyone know were I can find a rebuilt 9-5 V6 long block engine
Old 10-31-2007, 10:30 AM
Default RE: 1999 9-5 Turbo
What happened to your engine? Timing belt?
__________________
1999 Saab 9-3 5-door Stg4
Philly Region SCCA
Old 10-31-2007, 11:28 PM
Yea timing belt, then the piston took out a valve and you can image whathappened from there.
Old 10-31-2007, 11:40 PM
Is there any damage to the block? Was the piston damaged? If anything I'd rebuild the damaged head, it'll be MUCH cheaper than a rebuilt engine. Believe it or not, but that is a very common failure on the V6s and I've been lucky finding good deals on parts for that particular repair.
__________________
Philly Region SCCA
Old 11-01-2007, 12:09 AM
yea i will probably check into that. I have not done a complete tear down on this engine yet
Old 11-01-2007, 09:47 AM
Go ahead and take the heads off. You've got nothing to loose except a couple of hours of time. I've seen three rebuilds of these engines and it's usually a matter of a couple of valves which are around $10 each...plus new headgaskets and timing belt/tensioneer of course
__________________
Philly Region SCCA
Old 11-06-2007, 09:19 PM
do you a good source for these parts?
Old 11-06-2007, 09:51 PM
absolutely.
www.eeuroparts.com has always been good with communication and timely shipping.
__________________
Philly Region SCCA
Old 11-06-2007, 10:17 PM
Thanks for all the help I will let you know how it all turns out
