99 9 5 stalls then starts after a wait
Old Oct 24, 2006 | 12:23 PM
Stripercrazed's Avatar
Default 99 9 5 stalls then starts after a wait
I have a 99 9 5 4 cyl sedan with 140k miles. It has started to stall/not start at random times. It will often start when left alone for a bit. Had all filters changed, tune up, new gas, oil changed, etc - no help. By the time I get the car to the mechanic it starts and he cant find anything to work on. Possibly related info: Individual led cells on my radio screen go out then come back on for a psychedelic display, the ignition module has been replaced a few times (when that seems to go the car dies with no restart), i seem to go through headlights frequently. All info points to elec. trouble. Any ideas out there? There are way too many stripers left to catch to worry about my car!
Old Nov 2, 2006 | 09:19 PM
plosage's Avatar
Default RE: 99 9 5 stalls then starts after a wait
I had the same problem. The car would run fine, then not start after I turned it off.
The problem was a bad crank or drive shaft sensor. Have your mechanic look at it. The problem is that the problem is nearly impossible to diagnose unless the car has the problem while the mechanic sees it.
By the way, the problem gets worse over time.
Old Nov 5, 2006 | 08:58 AM
McDiesel's Avatar
That's right, that's what causing your problem.
It occurs when engine is warm only.
It shouldn't cost that much, don't know what prices they charge in the US but here (sweden) it's about 260$.
Old Jun 25, 2007 | 08:44 PM
davvver's Avatar
have you ever found out the problem with your radio screen and the missing pixels? my uncles has the same problem and I would like to know if there is an easy fix for it?
Thanks,
-Dave
Old Jun 25, 2007 | 08:47 PM
googleSID pixel fix
parkermoto
1974-1994 900
Sep 28, 2016 11:28 PM
Murph
1994-1994 900
Feb 10, 2016 06:51 AM
SaabMinny
Oct 22, 2011 04:24 PM
