headlight problem
Old Dec 31, 2010 | 12:40 PM
eliot's Avatar
Default headlight problem
Hi there, I have a 99 9-5 which is having problems with the headlights. I already checked the relay and it seems to be in good condition. Checked all the circuits and everything seems to function properly. I am now looking to find what else could be the problem, any ideas on what I should check? Thanks!
Old Dec 31, 2010 | 05:09 PM
Do they just not turn on? Will they turn on to high beam?
Old Jan 1, 2011 | 11:59 AM
eliot's Avatar
Only one of the high beams and only one of the low beams will turn on. These are on opposite sides. I checked the fuses already too.
Old Jan 13, 2011 | 09:49 PM
Try swapping the bulbs from left to right. If the low beam and the high beam still turn on on the same side before the bulb swap than it can be wiring or the socket, if not - just change the bulbs.
Watagatapitusbry
Oct 6, 2011 09:31 PM
JeffR
Aug 17, 2011 03:12 PM
chriswalstra
Feb 18, 2011 10:11 AM
2k195
Apr 23, 2007 06:16 PM
blane17
Apr 20, 2007 11:37 PM
