alternator install
Old May 16, 2010 | 06:18 PM
robsaab's Avatar
Default alternator install
I just found out i need to replace my alternator in my 2002 saab 95.. first does anyone have any info on how to do this,, also when i remove the upper engine mount do i need to support the engine at all..
Old May 20, 2010 | 10:33 AM
Saaber95er's Avatar
This link should help. Good Luck!
Old May 20, 2010 | 06:15 PM
robsaab's Avatar
okay battery is good and alternator is good.. 13.9 volts tested!!! but yet when i start the car only 11.8 volts is there.. At the alternator with the car on i get 0 volts with tell me i got a problem in the wire.. is there a fuse or what should i be looking for
Old May 20, 2010 | 08:27 PM
Saaber95er's Avatar
Check the connections to the alternator they could be loose.
Susanna Conway
Oct 23, 2016 03:46 PM
jlittle900
1974-1994 900
Sep 10, 2016 06:53 PM
02conv93
Feb 28, 2015 07:41 PM
gmwarranty
Feb 26, 2011 06:21 PM
