Antenna
Old Jun 15, 2009 | 06:52 PM
reidg's Avatar
Default Antenna
On my 1994 9000 aero turbo the motorized antenna stops at the last five or six inches when going down, the last section of the telescope id imagine...
Just wondering if there is anyway to easily take it apart or check it easily...
or if there is something i can do to fix it.
Thanks
Old Jun 22, 2009 | 10:01 PM
saabhakan's Avatar
Thanks
if sombody replacet the mast whit out removing the broken end pice inside the antenna motor this may hapen,take away the 17mm top nut and pull antenna mast out ,remove carpet,torx or 8mm holds the antenna to the body,remove fastners and el.cable and antenna cable,take out of car,remove bottom bracket 2x8mm bolts,leve drain hose,remove center nut 7mm,lift of round cover dont loos any washers and look howe the are installde,remove plastic wheel and turn it around some times ther is a 4'' plastic strip from and old antenna mast,remove,assambly revers order,dont tight the 7mm nut hard,just snug,install in car connect all wires,take the antanna mast and stick the plastic strip down the tube,you may have to stright the plastic strip in the end dont bend it to hard in may brake,have some body help you with the radio.turn radio on listen to antenna motor wen click noise stops push plastick strip so far it gose,turn radio of,if it catsh antenna mast pulls in,good luck
Roto
Oct 24, 2015 09:22 AM
DriverJon
Jun 15, 2015 11:06 AM
bill.pickowicz
Oct 8, 2013 06:31 AM
simmons156
Dec 28, 2011 06:57 AM
Swede115
Apr 29, 2007 11:18 AM
