New SAAB What upgrades
Old Jun 18, 2008 | 08:04 PM
az93t's Avatar
Default New SAAB What upgrades
I just got a 96 900 se 4dr turbo. I had a few questions on where to get parts and who's good.. also i have a couple small problems.
1 my car builds boost to 17psi and the drops and spikes while under full throttle? is this normal i've driven other turbo cars and never seen this before only when there is a leak or had a bad part but everything looks ok. any ideas>
2 also i can move my wastegate rod pretty easy so i figured it was bad. or is this another normal thing on saab
3 also i was woundering if i could use the Garrett gt25 off the newer saab 9 3 and how much boost i could pull out of it.
or could i use the garrett gt1549?
or would i be better offgetting some aftermarket turbo.
Old Jun 19, 2008 | 01:57 AM
Default RE: New SAAB What upgrades
Wastegate rod should not move easily...may be an issue there somethwere...also replace all your vacuum hoses, that could solve the spiking issue. As far as upgrades try genuinesaab.com, but fix any issues that the car has before upgrading
N1CK4ND0
Dec 19, 2013 05:26 PM
Willisattack
Nov 12, 2012 03:10 AM
Douglas0793
Oct 20, 2012 08:31 PM
Bikerbaz78
May 18, 2011 03:06 PM
wiscodread
Mar 23, 2009 01:55 PM
