97 SE turbo idle problem
Old Sep 29, 2012 | 12:32 PM
Hruke's Avatar
Default 97 SE turbo idle problem
Hello i just recently bought a 97 se turbo and it has a problem. From what i have read it looks like the throttle body or a MAS or w/e. The problem is at idle the rpms will jump up and down then the car will stall. Then you have to give it some gas to get it started and once it starts and you let off the gas the car will die again. Does anyone have the same problem? or know more then i do what the problem is? I also read that i can just take off the hose to the intake and spray some cleaner in there, disconnect the battery and then that should also help. I also just filled up the tank.
Old Oct 4, 2012 | 05:45 AM
dolqiu's Avatar
thanks for all the information guys
Maineguy
Mar 8, 2012 08:18 PM
tiodecember
Nov 30, 2010 10:03 PM
GreasyCaprice85
Nov 15, 2006 12:39 AM
9000Aeroguy1
Jul 25, 2006 05:30 AM
Tetzlaffino
May 3, 2006 03:39 PM
