-   1994-1994 900 (https://saabforums.com/forum/1994-1994-900-30/)
-   -   97 SE turbo idle problem (https://saabforums.com/forum/1994-1994-900-30/97-se-turbo-idle-problem-4802/)
Hruke Sep 29, 2012 12:32 PM
Hello i just recently bought a 97 se turbo and it has a problem. From what i have read it looks like the throttle body or a MAS or w/e. The problem is at idle the rpms will jump up and down then the car will stall. Then you have to give it some gas to get it started and once it starts and you let off the gas the car will die again. Does anyone have the same problem? or know more then i do what the problem is? I also read that i can just take off the hose to the intake and spray some cleaner in there, disconnect the battery and then that should also help. I also just filled up the tank.
dolqiu Oct 4, 2012 05:45 AM
thanks for all the information guys
