Engine Light
I recently purchased a 1996 Saab 900 Convertable. My engine light just came on and I am wondering how to check the code or find the code number?
Thanks for any info you can provide |
RE: Engine Light
Autoparts store that checks for free will do this for you.
RE: Engine Light
Most autopart stores (autozone/VIP/pep boys) will scan the OBD-II for trouble codes. Personally, I (rather, my dad) has an OBD-II scanner.
You can check the trouble code with this site http://www.obd-codes.com/trouble_codes/ edit: the receptacle for the OBD-II scanner is just above the pedals, look for a black plug. |
RE: Engine Light
Mass Air Flow Sensor.
99.9% sure. |
RE: Engine Light
Most T5 cars had a MAP sensor, the MAF came into play with T7 cars...
| All times are GMT -5. The time now is 05:20 AM. |
