-   Audio/Visual Electronics (https://saabforums.com/forum/audio-visual-electronics-23/)
-   -   Speaker wire in door (https://saabforums.com/forum/audio-visual-electronics-23/speaker-wire-door-369/)
lfab Nov 4, 2006 09:15 PM
Does anyone know which wire is the positive speaker wire in the left door. One is red, the other is yellow. 1995 900SE convertible
Des Nov 30, 2006 01:00 PM
RE: Speaker wire in door
Hi,
To find out which is positive connect a low voltage battery to the speaker wires, 9V.
The speaker diaphram should move in or out depending on the positive connection. If it moves out then which ever wire is connected to the positive on the battery is your + on the speaker.
Good luck
Des
