2002 Saab Sedan 93_Starting Issue
Old Nov 27, 2012 | 09:13 AM
02winconv93's Avatar
Default 2002 Saab Sedan 93_Starting Issue
I have a 2002 9-3 sedan, 2.0 turbo that sometimes will turn over but not start. Starts fine when cold, but when using sometimes will not start util you let it set for a while. The fuel pump energizes (can here it when turning the key), the engine turns-but will not fire. When it starts it runs just fine-no problems what so ever.
I think I can rule out fuel pump and ignition (???). I think it might be in the ignition switch -or maybe the key code??
Any ideas? Thank you.
02winconv93
Old Nov 30, 2012 | 07:38 PM
The problem is the crankshaft position sensor. 99% sure.
Old Dec 5, 2012 | 05:57 PM
Thank you, Roto. Is the sensor something a 'backyard' mechanic can change or replace? Or is this a take-it-to-the-garage' issue?
02 winconv93
dgroet
Jul 29, 2010 08:20 AM
stevealcemi
Jul 2, 2010 09:56 PM
robsaab
May 20, 2010 08:27 PM
gatr2000
May 17, 2010 05:22 PM
mellows
Mar 28, 2006 05:52 PM
