9-3 aftermarket headlights
Have to replace headlights and cornerside markers(clouded damaged ,dirty inside),and can't find anything but stock looking ligths ,but what i'm looking for is something like altezza lights look,but if theres no such thing i'll have to look for stock ones ,do you know where i can find them foor less than $150 or so fora piece? Thank you.
RE: 9-3 aftermarket headlights
Altezza [:'(]
Look around genuinesaab.com for smoked and E-code lights. That's about aall you can do. |
I'm not crazy about altezza either(looks to ricey to me),i just meant that i could find the headlights with projector lense or something like that that will make the car look a little more hot,but i dont mind the genuine saab look and i think that's one of the things that make this car an person who own it different from others.
you can always retrofit HIDs into it. A more expensive route, but will make it one of a kind...
i think i just go with xenon upgrade and put moremoney into mechanical part.
i just foun out that horn is not working where should i look ,fuses,conection?
just woundering where what fuse in the fusebox is responsible for horn.The escription on the lid doesn't say anything about the horn.
Is your SID unplugged by any chance? Try and see if fuse #1 is blown.Is your SRS light on by any chance?
What is SID?i checked fuse#1 and its fine but on the cover it doesn't say that is a fuse for horn,maybe there some other fuse or fusebox:eek:
SID is the system information display.
| All times are GMT -5. The time now is 09:45 AM. |
