Antenna Replacement
This is normally an easy task, and I've even done it on other vehicles in the past.
I have a replacement mast ready to go, but after removing the retaining nut I can not remove the old antenna mast, after switching the radio on and off again. There seems to be a sleeve on the outside that has a spring tab that doesn't allow it come OUT, but I can see how it could be pressed down into place. I can see this sleeve on the new replacement antenna mast I picked up at the parts department. So how do I remove the old antenna mast, without tearing out the motor assembly from inside the trunk? There has to be a simple trick to removing that sleeve. Thanks! |
Meh, I usually just take the whole thing out... its not that time consuming.
| All times are GMT -5. The time now is 05:40 AM. |
