broken rear view mirror
[&:] 95 9000cse, went to adjust the rear view mirror and the metal rod broke in half, it was hanging by a wire. Have it held up with cable ties now. Can I cut the wire, what is it for. I just assume replace it with a glue on version. Thoughts???
RE: broken rear view mirror
I cut the wire, no harm done
:D |
HI MATE, JUST NOTICED YOU ARE TALKING ABOUT USING A STICK ON MIRROR.
IN MY EXPERIENCE IT IS BETTER TO GET A PROPER REPLACEMENT IF YOU CAN, THE STICK ON ONES ALWAYS FALL OFF EVENTUALLY........ NOT SURE ABOUT THE WIRE, WILL HAVE A LOOK AND SEE IF I CAN FIND OUT WHAT ITS FOR.... |
JUST LOOKED IN MY HAYNES MANUAL, NO MENTION EVEN OF THE MIRROR ITSELF!!!!
CAN'T BE ANYTHING IMPORTANT THEN, I ASSUME. |
