front end
have a9-3 viggen 2000 front pass side i get that clack that sounds like a tire is going to fall off.ive been under it dont see any thing loose or cracked could it be lower ball joint. ps its gotten more frequent in the last wee k kevin
RE: front end
Does it happen when you turn or when going over bumps?
Re: Front end
Reading this thread Roto - I am experiencing the clacking/creaking sound from the front end when turning sharp at slow speeds & when going over bumps. Thoughts re: what is causing this? I checked/retorqued the front tire lugs, front struts appear tight, etc... Thx - Scott
[QUOTE=waseem103;15193]have a9-3 viggen 2000 front pass side i get that clack that sounds like a tire is going to fall off.ive been under it dont see any thing loose or cracked could it be lower ball joint. ps its gotten more frequent in the last wee k kevin[/
Pull plastic cap and check upper strut mount.QUOTE] |
Try pulling plastic cap and check upper strut mount.
Check your CV joints as well as the above. if one of the boots has a hole in it and it's clicking it's time for a new CV joint and boot. Not a hard fix. Couple hours in the driveway with the front jacked up.
