Interior Fan Stopped Working
I have a 2000 9-5 Aero and the interior ventilation fan just stopped. The fan speed adjustment seems to work, but the fan doesn't blow. I check fuses. Is there a relay too? Any ideas? TIA
RE: Interior Fan Stopped Working
best case scenario woudl be a bad switch, as that is probably the least expensive to fix...
For future reference: IF the fan made any noises before quitting it is most likely the blower motor.
you might want to find a repair chart i have seen a lot of blower modules go bad there on the right side of the heater box about a 1 1/2 square box just behind the console front panel
Do you mean the blower resistor or the relay?
Originally Posted by JettaRed
(Post 377)
Thank you. |
| All times are GMT -5. The time now is 07:28 AM. |
