low boost
i have a 91 9000 cd with a 2.3l turbo the car is very under powered and is not showing much boost on the gage any help i n solving problem i great
RE: low boost
Are you sure you don't have a boost leak? Any whistling noises under the hood?
RE: low boost
im not hearing anything at all nothing
RE: low boost
COuld be a few things. 1: your DV is worn and is venting. Or your wastegate could be stuck open...I would check the DV first. Do you have an underhood shot by any chance?
RE: low boost
well i found the problem it is that my turbo is bad the impellers do not move at all what i need to know now is what causes this
RE: low boost
damn...good thing these turbos are fairly common. Is there shaft play? It could be just oil cooked in there somewhere...can you move it with your finger?
RE: low boost
i cant get anything to move it sucks i need to know a good place to find a new one
RE: low boost
you have PM
RE: low boost
is there a better turbo i can get then the factory one
RE: low boost
give me a day and I'll tell you. I'm not familiar with your exact car, but I will look into it tomorrow.
| All times are GMT -5. The time now is 06:03 AM. |
