-   -   No heat in 9-3 ('02 SE) (https://saabforums.com/forum/general-auto-related-help-area-8/no-heat-9-3-02-se-3549/)
jerickson Jan 6, 2011 08:18 AM
Engine shut off, keys out of ignition, cabin air still blowing on high, despite fan level on display. Replaced ACC controller yesterday, fixed fan problem (now cabin fan turns off when car is turned off and fan speed level is again adjustable); however, now I have no heat (which before was fine). Any suggestions?
Thanks,
Jeff
Roto Jan 6, 2011 10:40 PM
There should be a procedure to calibrate all the air blend doors. That may be something that needs to be done. Did you have heat before?
jerickson Jan 7, 2011 08:15 AM
Yeah, I had heat right up until I changed out the ACC controller.
Roto Jan 7, 2011 03:07 PM
I'm fairly certain that the blend door is in the wrong position and needs to be calibrated.
jerickson Jan 10, 2011 08:19 AM
Problem solved. I check fault codes and they said I had air-mixer/sensor short or open circuit. Put old controller back in and got both the same error messages, plus a new one, so eliminated the possibility that I had a bad part. Replaced new one. Started fussing with the wiring and realized that I must have popped one loose somewhere during the initial replacement of the ACC controller. Found a loose harness (presumably to the air-mix sensor), snapped it back together, and, viola, I have heat. So, now I'm good until next weekend when I'll replace the hatch struts. Anybody know if I need a special tool to expand the clips, or can I fudge something together?
Roto Jan 10, 2011 05:33 PM
flathead screwdriver works...
