-   -   power window problems (https://saabforums.com/forum/general-auto-related-help-area-8/power-window-problems-1566/)
saab900 Feb 28, 2009 01:53 PM
Hi all im new to this site and new to saabs i recently pursched a 92 saab 900 turbo convertable and im having some problems with the driver power window when you turn the ignition on the window rolls down. also the top dose not work to lower the to you have to do it manually. ive checked all the fuses and relays for the top and the windows. any help will be greatly appricated.
thanks
matt
boostpowered Mar 1, 2009 09:18 AM
broken switches?short in wiring
saab900 Mar 1, 2009 09:48 AM
ive checked the wiring its all good ive also checked the switch and it tested good but its the master switch for the widows and i believe its a problem in the master switch just wanted a second opinion on it or if someone else has run in to the same problem and the top i figured out already.
thanks
boostpowered Mar 4, 2009 12:59 PM
check your ground if the switch tested good and you have power to the switch
and no rotten/cracked wires then you probably dont have a good ground
saab900 Mar 4, 2009 07:56 PM
ok thanks ill check that next time i work on it.
gatr2000 Mar 20, 2009 10:56 PM
i now have 3 out of 4 windows not working.. today my driver side window ..i roll it up and here this loud snap..i thought the window cracked...the motors on these windows are too strong for the cheap aluminum brackets...the motors should cut off once closed ..three out of 4 windows proves that wrong.
boostpowered Mar 21, 2009 09:38 AM
gatr 2000 replace those mounts with solid grade 8 bolts and locknuts the play in the mounts causes the cable to bind and it either snaps the cable or burns the motor up
