saab 900 wont turn over
I have a problem starting my 900. I turn the key and can hear the relay activate but the starter doesn't turn over. I have changed the starter, it still had the same problem temporarily but then turned over and ran fine for about 4 days, now it wont start again. I have checked the battery (it has 12.7 volts idle and 12.2-12.3 volts once the key is turned) and the terminals. I have also checked that I have power going into the starter on the main loom which it has (12.2-12.3 volts) Is there a common fault on the electrics circuit somewhere that could cause this or any other ideas would be appreciated.
I realize that this is an older issue and you probably have it solved by now but this sounds like a starter solenoid, when you swapped your started did it come with a new solenoid?
here is a link to some starters that we offer with new solenoids https://www.carpartsdiscount.com/sta...html?3594=1025 |
| All times are GMT -5. The time now is 10:26 AM. |
