is it a wheel bearing ?
I just purchased a 97 aero, which tested how strong a telephone pole is down the passenger side . Car has a noise like drivers side bearing bad when loaded to the right . are front wheel bearings going bad common on 9000 aero ? also has a high pitched bussing noise ,like alarm going off which seems to come from right rear speaker, any help?
RE: is it a wheel bearing ?
Can't hep with the speaker, but with the bearing: jack that corner up and try pulling on the wheel side to side. There should be o movement unless you pull strong enough to turn the steering. If there's any clicking when doing this it is the wheel bearing.
| All times are GMT -5. The time now is 07:20 AM. |
