wiper washer
My wipers work but the washer won't spray. no noise from the washer pump either.
Also, dome light does not light when door is open. Radio antenna motor disconnected by previous owner because it was oscillating up and down. Any Help or suggestions appreciated. Kevin |
RE: wiper washer
Get to the washer motor and test it...if it works than something is fried in the circuit. Did you try replacing the bulb in the dome light? Are you sure there is a problem with the antenna? Did you see that oscilation yourself?
RE: wiper washer
I have a windsheild washer[/b] on front,like many of our frens.Can any 1 suggest a good fluid to me.How 2 use it ? is it to be mixed wid water ? n whr will i get it.
Presently its useful having one in dusty dry conditions of this season.But am using plain water :).Will mixing a lil bit of surf! cause problems? to the motor spray etc.? |
