Excessive engine moke
Hello to everone, and thanks in advance, I have 1996 900SE 2.0 TURBO and the engine is burning oil, I have replaced the turbo (used) a few months back for the same problem, and it started smoking again, it smokes so bad I cause a complete smoke out behind me if I try to drive it. Has anyone had the same problem and if so what did it take to fix it.
HELP |
you should have replaced the head gasket not the turbo! it is extremly rare for a turbo to just start blowing oil unless you are running around with no air filter and abusing the hell out of it(over reving the turbo). remember if your having issues the last thing to be replaced unless you can see physical damage is the turbocharger.
howdy--can anyone direct me to where I can find the engine to chassis grounding point for my 94 camry?
are your sparkplugs oily?
| All times are GMT -5. The time now is 09:57 AM. |
