-   Off Topic (https://saabforums.com/forum/off-topic-6/)
-   -   9-3 Front Amplifier Fuse, F25 (https://saabforums.com/forum/off-topic-6/9-3-front-amplifier-fuse-f25-9324/)
jrobinson47 Mar 16, 2015 07:26 PM
My car (2006 9-3 2.0T) won't set more than a day before the battery is dead, this is with the theft alarm disabled. With ignition in OFF, I am seeing .33 amps in this fuse socket. Seems too high to me. What does this fuse supply?
jrobinson47 Mar 16, 2015 07:58 PM
Further Info on F25
Looking further, this appears to be for the Bose front speaker audio amp. I looked for where service manual says it should be, (rear of driver's side wheel well, I see only the bracket on the floor, no AMP. I removed F25, no codes or warnings, audio system works as before.
This is a base 9-3, is it supposed to have this AMP?
Also, this car has not had any audio out of the front door speakers (both sides) since I purchased in Sept 2014.
Am I on to something?
For now, I am leaving this F25 OUT.
jrobinson47 Mar 16, 2015 08:10 PM
9-3 f25
FYI, I also found no unterminated electrical connectors in the area of the amplifier.
