07 Saab 93 Drivers Side Headlight bulb replacement
This will sound dumb, but really, it's not meant to.
I know that you turn the rubber cover to remove it and access the bulb. I know that you twist the bulb to remove it and unplug it. I get all of that. How the heck to you get your hands between the windshield washer receptacle, the fuse box and the light? I don't think my 2 year old could get her hand in there. Do I have to remove the housing to replace the light bulb? FWIW, it is the drivers side low beam light. Thanks. |
Tight fit
Remove the top battery cover. Pull the neck off the washer tank. Remove the front engine mini fuse box (between the battery and headlight area) by releaseing the clip from the battery surround.Install new bulb and reassemble. Now the other part.... Check that the pig tail is not burnt, bare wires. If so they are cheap at your local dealer. About $17.00. If light still doesn't work....In the larger fuse box (next to the battery) you will find an orange relay. Wiggle it. If the light comes on you will need to replace that relay to the tune of about $150.00. Good Luck
Iguana, Thanks man, that worked great!
| All times are GMT -5. The time now is 05:25 AM. |
