-   -   2003 Fuel filter (https://saabforums.com/forum/saab-9-3-11/2003-fuel-filter-1000/)
jp57 Apr 26, 2008 08:54 AM
2003 Fuel filter
Does anyone here know the location of the fuel fitler on the 03 9-3 linear? I have followed the lines all the way to the rail and have not found it leading me to beleive its got to be hidden around the tank somewhere( I only had a limited time to look).
I have found on one website where it says there is a panel that you have to remove, but it doesn't say where the panel is located. I'll have a chance to look at it again today but if anyone knows the secret hiding spot, please let me know.
Thanks
hawaiisaab93 Apr 27, 2008 08:04 PM
RE: 2003 Fuel filter
id like to know I have a 03 linear also
Roto Apr 28, 2008 09:05 AM
Nice...looks like you guys have the fuel filter as an integral part of the fuel pump... so they probably mean the access panel under the bakc seat. I wouldn't bother with it unless the pump dies...
hawaiisaab93 Apr 28, 2008 09:30 AM
yea but I went to the dealer last night and told them that my gas guage has been acting wierd lately and he said it might be the fuel pump..this is gonna suck if i have to replace that
jp57 Apr 28, 2008 12:12 PM
Here's where I am now.
Put the car up on the lift yesterday. Looked up at the area around the tank. Went to pull the evap canister down to look above it but was unable to get it down. Removed the r/r inner fender trim hoping to be able to see something but was not. Removed 2 child seats and removed my back seat bottom and found no access panel. I'm was at the point that I almost dropped the tank. The only reason I do not think it is in the tank is, it is a big filter. I have seen the in tank filters but this does not look like one. It is a standard metal filter with threaded holes on both sides. Usuallyin tank filter are plastic with quick connects.
Roto Apr 28, 2008 01:21 PM
are you sure you're not looking at a previous generation fuel filter? You're describing what I have and I'm 95% certain that your car has an intank filter which is replacable with the fuel pump assembly.
jp57 Apr 29, 2008 12:58 PM
What is your guys opinion
At 70k miles and 24.5 mpg average would you take the time to replace it? Keep in mind if I take the time to drop the tank I'll replace the pump too while I'm there.
Roto Apr 29, 2008 01:34 PM
you'd have no choice but to replace the pump:) I estimate the whole thing costing you $700 if you were to drop the tank or a little less if you were to get an access door cut under the rear seat to get to the tank. I don't quite think that it's worth it...I'd much ratherput that $700 aside ...
hawaiisaab93 Apr 29, 2008 07:36 PM
I just got my saab back from the dealer today..I need a fuel pump/gas guage sending unit/secondary air pump and valve replaced...for a grand total of 1100 dollars..and it gets dont next friday...lucky me...ugh imma be so broke after this one..right now im getting like 10 mpg
Roto Apr 30, 2008 08:38 AM
10 mpg isn't that bad...consider that I get 14mpg on my tune....and that's highway and 94 octane.
