9-3 turbo swap
Old Apr 29, 2010 | 03:31 PM
btbw92091's Avatar
Default 9-3 turbo swap
hi i have a 01 9-3 se 2.0 turbo and my turbo is making a whop whop whop sound when i letoff the gas my teacher at uti says its the bearings in the turbo its also leaking oil now what im wondering is can the aero hi output turbo be used on the regular 9-3 with a normal turbo or will i need to upgrade the injectors and such also can i buy a rebuild kit and rebuild it myself? thanks in advanced
Old May 4, 2010 | 11:15 AM
029-3SE215hp's Avatar
As far as I can find dealing with my own turbo problems, rebuilding the turbo is a quite a task and you must have specialized tools to rebuild correctly. Used and rebuilt turbos are all over the internet for between $100 and $600.
I also found that you can use the Mitsubishi turbo from the Viggen in the Garrett models with one line and banjo bolt modifications, but do not expect a HP gain with out having the ECU reflashed.
JeffR
Aug 17, 2011 03:12 PM
Audi Dan
May 9, 2011 12:21 PM
Wildvan07
Aug 26, 2010 04:56 PM
bumpinsizaab
Sep 10, 2006 08:41 PM
bumpinsizaab
Sep 5, 2006 10:59 PM
