AUTO Tranny Service & Oil Type
I don't have a manual that tells me when to service the transmission. I wanted to know at what mileage do I do this, and what type of fluid is required. Also, is there a filter in the transmission...I was going to do a "BG" flush which exchanges the used fluid with new fluid via a line hookup. Any advice???????????????????????????????????????????? ????????
dexron 2 atf, change fluid and filter every 30,000 miles if you drive mostly on the highway,every 15,000 miles if you drive in the city/hot climates/ or drive like a madman.
the flush is good at getting the old fluid in the torque converter but not good if you want to inspect the quality of your transmission (eg.metal flakes in fluid)
Meinhaj Hussain
Aug 6, 2007 12:14 PM
