defective fuel gauge
Yesterday after a fill up, my gas gauge started to work intermittently. It shows full, then after a while empty, then full again and so on.
I did not notice any correlation with the slope, speed or road structure. I have no ODB error code detected neither. The car is a 93 Aero from 12/2001. I see on forums that the fuel sensor has to be changed. Do you know if the fuel sensor on my model can be changed independently or if I have to change the entire fuel pump. And would you have indications on the procedure to follow? Many thanks. |
| All times are GMT -5. The time now is 09:43 AM. |
