GlobalTIS
I am looking for some advice on Global TIS installation. I have gone through the procedure. I cannot see how to get the subscriber ID. I have the 64 digit registration license., without subscriber ID I am stuck. There is reference to a file called kg.txt in the lib file. I can see keygen and keygen.class but no kg.txt. I beleive that file should contain both subscriber ID and the license. Thank you
That's a tricky spot to be in with Global TIS, especially when you're stuck on the Subscriber ID. It sounds like you're working with one of the unofficial versions, as the official Global TIS https://tropical-casino.com/ usually comes with a subscription and a straightforward activation process.
| All times are GMT -5. The time now is 01:32 AM. |
