HELP! total dashboard craziness! Follow up to rear wheel hubs!
When it rains it pours!
So I check tire pressure filled up the tires evenly with air and checked the hubs by seeing if there was any play in the wheels, nothing seems to be a miss but the noise still exists... BUT get this: We drove about 10 minutes and then the following lights went on on my dash: WARNING CHIME GOES OFF AND WE GET: Large red triangle with exclamation point TCS light "TCS off" light ABS light BRAKE light in yellow circle Check engine light Speedometer stopped working Pulled over seemed to be idling a little rough but not too bad, may be a coincidence. Then we turn around to go to go home and call my mechanic....after about 10 minutes all of the lights go back out, the speedo goes back on...but the check engine light STAYS on... Thoughts?? Matt Winkler |
First of all get the CEL pulled and post the code back. The TCS light and the Speedo stopping working means that the wheel sensor connections need to be cleaned...may be it is related to your hub noise since the wheel sensor is part of the rear hub assembly. First try to clean up the contacts on those sensors...
| All times are GMT -5. The time now is 06:09 AM. |
