Hot start issues
Yesterday, my 2002 9-3 wound not start after the car was at temperature. I saw on another thread that the Crank case position sensor could be the issue. I recently changed that (3 months ago) while trying to solve another problem.
Is there any other possible issues I could look for other than the CPS? I did get the last CPS on line and it could be defective, I guess. Will have to try again if there is nothing else to check out. |
could be a fuel injection fault,also check and clean/ replace air filter element,check engine breather hoses are okay ; a diagnostic check on a Saab tester, may show some error codes to point you in the right direction
| All times are GMT -5. The time now is 05:15 AM. |
