knocking noise steering
Just bought the car yesterday and didn't notice a knocking noise when I turn the steering wheel.
It seems to only happen when the car is stationary and it seems to be no the near side. Can anyone help with this one? Thanks |
RE: knocking noise steering
Check the tie rod ends first. If the boot is torn than that's your problem - replace it. You can also lift the side of the car a little so the wheel is off the ground and try pulling it as if you were turning the steering, that could also help with finding the knock.
