Power Steering Fluid Leak
My 2003 9-3 has a slow power steering leak. It appears that the leak is between the resevoir and the pump. Is there a gasket or something that can be replaced first. I was told that I had to replace the entire pump assembly.
Thoughts? Thanks |
i had the same leak
i had the same leak about 3 months ago. i found that the hose between the reservoir and the pump had rotted and cracked inside the portion where it leaves the reservoir, so the fluid was leaking on the underside of that hose. replace the hose or if you can repair that portion.
| All times are GMT -5. The time now is 07:04 AM. |
